cyl head
Hi Baz,
will fit no problem, main difference is 8mm exhaust studs in stead of the 900's 6mm but you can drill out exhaust pipe retainers to suit or obtain z1000 set. Obviously a MK1 head is preferable as the later heads although will fit can have a more square shape to them. Might be best to advise what model of Z1000 head you have as some even later models can be fitted with modifications, but there are plenty of experienced experts here that would be willing to advise if this is the case. Alex.
Hi Baz,
will fit no problem, main difference is 8mm exhaust studs in stead of the 900's 6mm but you can drill out exhaust pipe retainers to suit or obtain z1000 set. Obviously a MK1 head is preferable as the later heads although will fit can have a more square shape to them. Might be best to advise what model of Z1000 head you have as some even later models can be fitted with modifications, but there are plenty of experienced experts here (not me) that would be willing to advise if this is the case. Alex.
