Engine case cleaning
asphalt900
Hello everybody. This is my first post so excuse me if i'm in the wrong section. Looking for an option for bead-blasting cases for uniform apperance. You guys all do such a fantastic job of restoring/modifying these bikes!! Water-blasting was mentioned, is this the same as steam cleaning? And is it truly effective as to remove all grime reestablishing a like new apperance. Or is there another method? Thanks, Clay
phil churchett
