It it safe to move the cams around without a shim in the top of the bucket, so that I can juggle my gaps.
Cheers Rob
Valve shims
Valve shims
You can do it, but my advice is that you are best checking your gaps and working out the shim size required and just getting some plus a valve shim tool to hold the bucket, I recommend the kawasaki type and not the "Motion Pro" one.
If you do it the way you are suggesting, do it very slowly and carefully, also watch that the cam lobe does not contact off the edge of the bucket when rotating.
Rob, here is a handy way of finding the shim size you need for each valve that's out of tolerance so that you know exactly which size you need.
Figures are example only:
Actual measured clearance 0.52mm
Subtract specified clearance -0.15mm = 0.37mm
Existing Shim size 220
Add excess clearance 37 = 257 (round to nearest shim size, ie. 260)
