Just about to split my Z1000 crank cases its fitted with dyna s ignition do i put a punch mark on the timing plate and the crankcase to act as a timing mark
this may be pretty obvious question but as they say if you aint sure just ask.
Dyna s timing marks
Dyna s timing marks
Mikey, always a good idea to clearly mark where everthing was for future reference. I've fitted Dyna S to my Zed too! If you need any help I'll be glad to pop up to you one evening/weekend to assist, & give you me stuff for polishing too!
See you 25th anyhow, for the ACE adventure!
