Carbs or ignition
tlc
International Rep
#16 PostAuthor: tlc » Wed Oct 14, 2009 8:03 pm
02GF74 wrote:any idea how long it takes to arrive over this side of the pond?
4 days from the States.
Then 4 weeks to your door :evil:
Asphalt Cowboy
mikey
#17 PostAuthor: mikey » Wed Oct 14, 2009 8:33 pm
Thats a day and a week for each carb :lol:
mick znone
#18 PostAuthor: mick znone » Wed Oct 14, 2009 8:37 pm
4 days from the states, then 2 to 3 weeks from the post office.
1340fxd
#19 PostAuthor: 1340fxd » Wed Oct 14, 2009 9:30 pm
While you are waiting - I had a similar problem and got some advice from one member that worked - basically it was the idle pilot jets that were set too rich and the bike ran fine on old plugs. After fitting new plugs (modern plugs appear to like to run lean) the problems started.
Solution was to clean the new plugs thoroughly then re-set the pilot jets to one turn out (i.e. lean) and take it from there - worked for me.
Dear Santa, please can I have...
coldsummer
#20 PostAuthor: coldsummer » Wed Oct 14, 2009 10:03 pm
Mikey, I ordered some stuff last Thursday eve and it was delivered today so call it one week. I paid the slightly higher shipping charge to get it sent via UPS. A good investment cos it can take ages for the Post Office to deliver if you use standard postage especially with the current crappy postal strike/go slow whatever it is!
mikey
#21 PostAuthor: mikey » Fri Oct 16, 2009 11:09 am
Visited steve today (aka ginger bear) and i didnt get lost getting there, he is very kindly doing my carbs in his ultra sonic tank and ordered my repair kits from Z1 enterprises so hopefuly when its all glued back together it will be running nicely just in time for the winter to start :roll:
Geoff Meager
#22 PostAuthor: Geoff Meager » Fri Oct 16, 2009 2:18 pm
Mikey .. I know its a bit late ... but the Carb Kits from NRP are the nuts ....
as recommended by chrisu
Come complete with all jets & gaskets including new float valve .... all for £17 each carb
mikey
#23 PostAuthor: mikey » Fri Oct 16, 2009 6:10 pm
Thanks geoff anyway, but the kits from Z1enterprises are very comprehesive and include all the gaskets o rings jets and needle vavles etc and with the postage worked out to be just over the £50 mark for all 4 carbs.
