Carb Recognition
carpy
Carb Recognition
#1 PostAuthor: carpy » Tue Sep 29, 2009 6:46 pm
Hi all, I've got a 1978 KZ1000 with 900 barrels on it and as it's running rough as heck I think I need to check the carbs. Problem is I have no idea what carbs are on it, 1000 or 900 or what variant. There are 2 fuel inlets on them. Does anybody know how I can tell different ones apart.
Many thanks
Steve
phil churchett
#2 PostAuthor: phil churchett » Tue Sep 29, 2009 6:59 pm
Would be easiest to post a picture.
You will need a photobucket account;
http://photobucket.com/
popsA1
#3 PostAuthor: popsA1 » Tue Sep 29, 2009 7:34 pm
My z1000 has had many different carbs over the years. Currently I’m running a set off a Suzuki. If yours have twin fuel pipes its safe to say they’re from a Kawa. Next, does yours have the traditional pilot airscrew on the side of the carb? A1’s and A2’s didn’t have this screw but they do have a by-pass screw underneath, set into the front of the float bowl.
As Phil said - a picture will tell a thousand words.
A2 1979-80. A1 1980-now
Davy Doherty
#4 PostAuthor: Davy Doherty » Tue Sep 29, 2009 7:47 pm
Go to Jeffs, z1enterprises .com site there is reference info page which will help you out.
Life's too short!
carpy
#5 PostAuthor: carpy » Tue Sep 29, 2009 8:08 pm
Thanks for the replies. Will try to post some pictures tomorrow.
Steve
mick znone
#6 PostAuthor: mick znone » Tue Sep 29, 2009 10:09 pm
carpy
#7 PostAuthor: carpy » Wed Sep 30, 2009 10:08 pm
Hopefully here are some pictures.
Steve
Sorry about the size, complete amateur
Steve Cooke
#8 PostAuthor: Steve Cooke » Wed Sep 30, 2009 10:31 pm
They're 28mm carbs from an earlier Z1 and although usable there not correct for your bike they should be later 26mm ones, it may just be the picture but the air screw looks like it's backed off too far, those pods wont help either.
000zeds
#9 PostAuthor: 000zeds » Thu Oct 01, 2009 7:31 am
Carpy you say it has 900 barrels , Is it definately 900cc ? It might be a big bore kit in 900 barrels !
Zeds-R-Us
popsA1
#10 PostAuthor: popsA1 » Thu Oct 01, 2009 8:51 am
Those 900 carbs will work fine with K&Ns providing they’re jetted right.
But first, get yourself a Gunson Colourtune ( http://www.halfords.com/webapp/wcs/stor ... &langId=-1 ) and get the mixture right at tick over.
If there’s any difference in the number of turns of each air screw you’ve got a blocked jet or passage.
The air screws should be between 1 and 2 full turns out. Ideally, 1.5 turns out. If they’re not, you need to change the pilot jets.
This of cause is assuming you engine and ignition are both sound.
carpy
#11 PostAuthor: carpy » Thu Oct 01, 2009 1:15 pm
Thanks for the replies. The K&N's will have to stay as I don't have the standard airbox unfortunately. I couldn't tell if it has got a big bore kit fitted to be honest.
The engine will run but it will not tick over and it runs intermittently on different cylinders which is why first off if I could find what carbs were on it then perhaps I could find what jets were required and all the other settings. Process of elimination I suppose.
