charging
MAC777
charging
#1 PostAuthor: MAC777 » Sun Sep 20, 2009 7:26 pm
hi where is the best place to get a reg /rect for a kz1000 77 thanks in advance :D
000zeds
#2 PostAuthor: 000zeds » Sun Sep 20, 2009 7:27 pm
Z-Power 01942 - 262864
Zeds-R-Us
#3 PostAuthor: PAULJAC47 » Mon Sep 21, 2009 5:22 pm
A Superdream unit works fine 250 or 400 get a good secondhand one Cheers Paul J...
MAC777
#4 PostAuthor: MAC777 » Wed Sep 23, 2009 7:21 pm
you must be joking i thought this price was in dollars but no , :cry:
there must be a cheeper unit
phil churchett
#5 PostAuthor: phil churchett » Wed Sep 23, 2009 7:55 pm
paulmceleney
Chunks
#6 PostAuthor: paulmceleney » Wed Sep 23, 2009 8:00 pm
westcountry windings 01279 731172 i paid about 35pounds for my
KeithZ1R
#7 PostAuthor: KeithZ1R » Wed Sep 23, 2009 8:00 pm
phil churchett wrote:http://www.electrexworld.co.uk/rr10-universal-regulator-rectifier-electrical-parts-for-motorcycles-electrex-world-527-0.html
All my bikes have these fitted excellent unit trouble free
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
MAC777
#8 PostAuthor: MAC777 » Mon Sep 28, 2009 8:05 am
went to the local breakers and found a cg125 with 500 miles on the clock got the reg/rect for a £10 ,problem solved.
eastlondon
#9 PostAuthor: eastlondon » Mon Sep 28, 2009 11:45 am
MAC777,
Can you post some instructions on how to wire up the CG125 reg/rect ?
#10 PostAuthor: PAULJAC47 » Mon Sep 28, 2009 4:35 pm
Nice to see H****s have some use is the unit the same as the one i recomended from the wet dream series??
MAC777
#11 PostAuthor: MAC777 » Mon Sep 28, 2009 6:35 pm
well remember the cg125 was a new one 12volts electric start,the reg/rect is mounted on the right at the steering stem.
five wire , 3yellow,1green,1red
3yellow to the 3wires from alternator
1green to earth battery earth on engine
1red into the double red and white at battery
i fitted an in line fuse on the red wire to be safe,and mounted the unit on the electric board above the battery.
14.1volts with lights off 13.8 with lights on better than 16volts and done for £10
02GF74
#12 PostAuthor: 02GF74 » Mon Sep 28, 2009 9:13 pm
hahah cg125 is the only other bike I've owned so have the Haynes for it.
haynes shows it as 6 V but I know mine was 12 v ... and in fact there is section for Brazillian model as b eing 12V, whcih mine was...... but the wiring diag shows 2 phase generator, Z has 3 phase, hmmm...
also the CG125 bulbs are of lower wattage than Z
35/35 W headlamp
21/5 W stop/tail lamp
18 or 21 W indicator
cf Z
50/35 W head lamp
32/4 W stop/tail
23 W indicator
so not that much difference but may be enough to cause probs.
I have GPZ 550 rectifier/regulator unit that I will get round to fitting once I have sorted hte engine - doesn;t seem to be finring too well on left hand 2 cylinder - pipe from tank not clear?
MAC777
#13 PostAuthor: MAC777 » Tue Sep 29, 2009 8:00 am
first i cant remember wot a superdream unit looks like but the cg is small about size of a 10 pack of cigs,
def 3 yellow wires same as comes from alternator.
as for bulbs you only get 21/5 tail bulbs from retailers,
headlight 60/55 h4 so yes it may take a bit more
so long as its putting out over 13 volts with the lights on all should be well.
got a blackbird one as well much bigger may try that ,its got 7 wires
it was a brazil bike think they all are now
#14 PostAuthor: Rich » Tue Sep 29, 2009 5:46 pm
superdream = SH232
It has a voltage sensing wire (black) goes to Kawa Brown, Red to Red/white Green to earth (black/yellow).
Three wires yellow to alternator stator
MAC777
#15 PostAuthor: MAC777 » Tue Sep 29, 2009 6:18 pm
thanks :D i will check it out at the weekend,must get the zed moted, and ive an r6 to finish if the postmen stop going on strike. :(
