Hi, my z1000 dropped onto 2 cylinders on the way to work this morning, it's lost the outside 2. I swapped the plugleads outer for inner and swapped the trigger wire to the coils and the other coil will work the middle cylinders so it's not the coil. It's got a dyna s ignition which all looks ok under the cover. Any ideas? The Dyna s is less than 2000 miles old.
Cheers, John.
Running on two
Well I narrowed the fault down to the Dyna S sensor on the crank. Dynatek are the agents so I rang them. I told them that it was 2 or 3 years old but only fitted recently and they said send it to them for testing.
They have sent me a new one free of charge.
Big thankyou to Dynatek!!
Buy some stuff off them!!
John.
John.
