z900a4 front discs
ian penman
z900a4 front discs
#1 PostAuthor: ian penman » Thu Apr 23, 2009 3:36 pm
Need 2 front discs for a z900a4. 4 bolt fixing and 290mm.
Mine are down to 4.9mm thick! HELP.
bigmac103
#2 PostAuthor: bigmac103 » Fri Apr 24, 2009 7:41 pm
I run two 4.5mm discs on mine, do you mean 6mm? 290mm seems a little thick to me.
Lost in the desert somewhere
ian penman
#3 PostAuthor: ian penman » Sun Apr 26, 2009 8:57 am
I think they start at 6mm. My discs have over 100,000 miles on them so I cant really complain.I was told they are 7mm new but I'm not sure.
bigmac103
#4 PostAuthor: bigmac103 » Sun Apr 26, 2009 11:06 am
Wow, that's good milage. As you say fantastic value. I got mine off fleabay for a tenner each. The minimum disc you can use is 4.5mm.
Gary
#5 PostAuthor: Gary » Sun Apr 26, 2009 1:38 pm
Hi,
i think there are two thickness of disks for the Z900 depending whether you have a KZ900 or a Z900, as far a i know the the KZ900 in the USA has 6mm and i am pretty sure the UK had 4.5mm.
the KZ900 only had a single disk fitted and the Z900 in the UK had twin from disks.
i may be wrong though....
Ian, i think i may be able to help you, i'll get back to you shortly
Gary
Users browsing this forum: Bing [Bot] and 11 guests
