Z1r
Nothing genuine for a z1r is cheap, I would expect to pay 800 to 1100 for a top condition pipe set, the Italian set has been on the market for a while, start negotiating with the seller see if he budges ,  I got a nos set of pipes for my 250, even rarer than a z1r  for £380 , seller wanted €800 to start with, bargain
									CB125  GT380  CB750F1  Z1R  GPZ 750 Turbo  Z1R
						Underside shot shows a long dent on one side from scraping.
Side heat shields both missing.
silencer would need swapping for a new one IMHO
It's worth what he can get but I would not go more than £600 for what is usable there.
You can factor another 500 for the new silencer/ bracket/clamp and a good pair of heat shields with retaining clamps.
The inner downpipes will separate so could be re-chromed if needed.
But they are probably good for nearer a grand if he can persuade someone to keep and use that end can.
From Mark
From Mark
Z1-R D1, Z650 B2, Z1-B & ZRX 1200 A1P        Catch 'em if you can at www.Zedrider.co.uk
						pertonpc wrote:Underside shot shows a long dent on one side from scraping.
From Mark
Hi thanks for the input, is there a problem with the silencer? Why would you swap it for a new one?
Hi thanks for the input, is there a problem with the silencer? Why would you swap it for a new one?[/quote]
because if u used that in our shite climate it would look like this
and if you get one with the part no's on its a warranty replacement best off with a repo one if using in our country save all good ones for the collector out there
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
Z1OC # 886
