Z 1000 Discs
DavidZ1R
Z 1000 Discs
#1 PostAuthor: DavidZ1R » Mon Sep 19, 2016 7:20 pm
Anyone out there have a set or individual discs to fit a 1000a1 undrilled if poss, even willing to part with money :lol: pm me if you have cheers
#2 PostAuthor: paul doran » Mon Sep 19, 2016 7:46 pm
what date discs do You need
Hasbeen
#3 PostAuthor: Hasbeen » Mon Sep 19, 2016 8:49 pm
I have quite a few in garage drop me a pm if interested.
Nick
DavidZ1R
#4 PostAuthor: DavidZ1R » Tue Sep 20, 2016 7:37 pm
paul doran wrote:what date discs do You need
Not sure the date disc, just undrilled front and rear 1977 a, trying to restore one, if that helps Paul
#5 PostAuthor: Garry.L » Tue Sep 20, 2016 8:45 pm
Do you know when your Thou was built David?. If so Paul may have discs he could match to your bike from their Date Stamp.
http://kawtriple.com/mraxl/tips/datecodes/datecodes.htm
DavidZ1R
#6 PostAuthor: DavidZ1R » Tue Sep 20, 2016 9:18 pm
Cheers garry, most of the bike is away, I will check what I have left here tomorrow.
DavidZ1R
#7 PostAuthor: DavidZ1R » Wed Sep 21, 2016 7:59 am
Having checked out date codes from what I have to hand, I have a letter U stamped on the shocks, what looks like 01 or 81 7 22 number inside the points cover, and 6 11, and 6 12 stamped on the handlebar controls, nothing on the carbs that I can see, so what should be the date stamp for the discs ?
#8 PostAuthor: Garry.L » Wed Sep 21, 2016 9:52 am
DavidZ1R wrote:Having checked out date codes from what I have to hand, I have a letter U stamped on the shocks, what looks like 01 or 81 7 22 number inside the points cover, and 6 11, and 6 12 stamped on the handlebar controls, nothing on the carbs that I can see, so what should be the date stamp for the discs ?
Switch blocks are Nov/Dec 76 so presuming they are original to the bike then somewhere around 1V on the discs would do IF possible.
#9 PostAuthor: paul doran » Thu Sep 22, 2016 5:02 pm
I will take a look Saturday
