Wanted Z1B Parts
- z1bnackerkwacker
Wanted Z1B Parts
Wanted Z1b 900 parts, rear wheel spindle complete with nut/ washers, spacers and tensioners, not sure if I need swinging arm pivot spindle as well (j.m.c fitted) never really looked if standard is used, will check that out tomorrow...
- paul doran
- z1bnackerkwacker
Spindle
Thanks Paul, none this way, only sheep, will check tomorrow if any bits are standard or jmc, I bought a standard swinging arm years ago, but it's bare, want to fit my centre stand but can't due to braced jmc, I have toyed with idea of cutting brace off, may be a bit drastic tho, thanks again, Andrew....
Finally getting my arse round to a bit of Zed work, not sure if swinging arm pivot is standard, think wheel spindle is J.M.C........
