Z1000 MK2 parts
Z1000 MK2 parts
Hi all
I'm on the lookout for a Z1000 MK2 frame with tank / panels / seat & V5.
Does anyone have anything knocking about, or can point me in the right direction
Rgds
Rgds
- mick znone
you would be best off putting mk2 parts or even the parts themselves in the title mate, you may miss someone with these items because it looks like you want a whole mk2 in the title.
- mick znone
- paul doran
- paul doran
neilbarrett
Tail units come up on ebay (far cheaper than pattern one), I sold one recently to someone in Japan for about £30. ST ones are usually cheaper but they are slightly different, they have a recess part where the seat goes (so hidden with seat down) but they fit and are identical otherwise. Maybe not an issue if you are building a special? There are MK2 side panels at £33 each on ebay as well now. Good luck with your project, the MK2 is my fave of all. Let me know if you are stuck with a tank, I might be tempted to sell mine. Might.
1979 Z1000ST
Redbeard wrote:Tail units come up on ebay (far cheaper than pattern one), I sold one recently to someone in Japan for about £30. ST ones are usually cheaper but they are slightly different, they have a recess part where the seat goes (so hidden with seat down) but they fit and are identical otherwise. Maybe not an issue if you are building a special? There are MK2 side panels at £33 each on ebay as well now. Good luck with your project, the MK2 is my fave of all. Let me know if you are stuck with a tank, I might be tempted to sell mine. Might.
Thanks for that, I wasn't aware of the similarities. I've checked out the Z Power ones - they are a contender. If I get stuck I shall of course put a shout out on here.
- paul doran
- paul doran
