Spacer, 42036-024
Paul Whitehouse
Spacer, 42036-024
#1 PostAuthor: Paul Whitehouse » Thu Jun 04, 2015 8:24 am
Chaps,
I'm in need of the internal rear hub spacer (sprocket side), 42036-024, suitable for a 77 Z1000 A1.
If someone has a spare one that they're willing to part with, then that would be brilliant. Failing that, if someone has one that they could measure up for me so that I can machine a new one.
Cheers.
[img][img]http://i1126.photobucket.com/albums/l610/YT1961/77%20Z1000-A1%20REAR%20HUB_zpsjypn9fzw.jpg[/img][/img]
If it's too loud....too bad.
hillbilly
#2 PostAuthor: hillbilly » Thu Jun 04, 2015 10:41 am
I have a mk 11 one.
Paul Whitehouse
#3 PostAuthor: Paul Whitehouse » Thu Jun 04, 2015 11:37 am
Cheers Hillbilly...does the Mk II use the same spacer then: 42036-024
garyd
#4 PostAuthor: garyd » Thu Jun 04, 2015 5:29 pm
Be careful, pretty sure there are some differences heree.
I went racing with my Zed with spokes and took a spare set of z100 alloys.
When the rear tyre gave up, I thought I'd just swap the wheels but the specers were different. So that scuppered that weekend.
#5 PostAuthor: chrisu » Thu Jun 04, 2015 7:29 pm
paul
i've got a few spare spacers - do you know the dimensions ?
they do vary as has been said
Paul Whitehouse
#6 PostAuthor: Paul Whitehouse » Fri Jun 05, 2015 7:52 am
Hi Chrisu...cheers mate. no, don't know the dimensions, only know it as a part number, unless someone on the site has one that they could take some dimensions from.
walshyco
#7 PostAuthor: walshyco » Sun Jun 07, 2015 1:15 pm
Hi Paul, I have one from a Z1000 A1 wire wheels. I really want to keep it but you are welcome to borrow it to make one up. If you still need one pm me your address and I will send it to you, to make a copy. Sean.
Paul Whitehouse
#8 PostAuthor: Paul Whitehouse » Mon Jun 08, 2015 8:35 am
Hi Sean, many thanks mate...much appreciated. I've PM'd you my address.
Users browsing this forum: Bing [Bot] and 14 guests
