as above gang, i'm after a set of carbs for my gpz1000rx
i been told that ZRX carbs are a direct replacements as well
the carbs doesn't have to be top flight as i can make one good set up with the carbs i've already got
must be prepared to post (if ur not close to south wales) wrap for a courier or meet me half way type thing
thanks in advance of any offers or info/advice
ZRX or RX CARBS
- Regular Poster
ZRX or RX CARBS
GO HARD OR GO HOME
- Regular Poster
- Regular Poster
pretty sure they won't fit. The cam chain on the RX is in the side. Both the J and Zephyr have a central tunnel, so the spacing between 2&3 will be wrong.
Try to spot all the derivatives of that style of engine.
Maybe the GTR1000 ( Suspect they are smaller)
ZL1000 same as above.
What about the GPZ900?
But thinking about it, the ZRX seem to be the logical answer If you can't get another set of RX ones.
