Z650c3 lh switch gear. Triangular master cylinder. 276m disc
z650freak
#1 PostAuthor: z650freak » Sat Aug 09, 2014 8:07 pm
Has anyone got on theirs shelves:
Left hand switchgear. Whole or in parts. Hi low is broken on mine.
Triangular front brake master cylinder. Perch has been bodged by previous owner.
276mm rear drilled disc(there are two sizes)
Also interested in any other bits for a c3 that you may have. Cheers. Paul
GPRD
#2 PostAuthor: GPRD » Sun Aug 10, 2014 8:43 pm
IS it just the Hi/Lo switch bit you want, or the whole unit?
I have a triangular master cylinder, but its in a bad way, if you can do something with it, you're welcome to it, as with the switch bit.
I have a rear disk, the drilled type? not sure of the size though, but I'll check.
What we got here, is failure to comunicate.
z650freak
#3 PostAuthor: z650freak » Sun Aug 10, 2014 8:53 pm
Thanks PM sent. Cheers. Paul
Users browsing this forum: No registered users and 5 guests
