Fork Tubes
Fork Tubes
Part Code: 44013-1003
Needed to replace a heavily pitted set on my Z1000H.
Early tube's are easy to replace with pattern parts, anything from the Z1000A2 onwards is a bit harder. Try Hard Chrome Plating & Grinding.
http://www.hardchromeplating.co.uk/
I've used 'em several times, excellent work, just never quite as quick as they'd have you believe.
Ginger Bear wrote:Early tube's are easy to replace with pattern parts, anything from the Z1000A2 onwards is a bit harder. Try Hard Chrome Plating & Grinding.
gb where are they situated
their address says kingsmill way ( literally around the corner from me ), but, their map shows them at boughton camp ( an old industrial estate/army base at ollerton).
I think i'll go looking tommorrow.
I think they may have gone through 'the hoop' and started up again as 'Hard chrome plating', where they were previously trading as 'Hard chrome plating & grinding'.
That's probably why there's a conflict with the address. Might be worth a phone call?
I have used them in both guises, excellent work on both occasions.
- bulldogbobby
Ginger Bear wrote:I think they may have gone through 'the hoop' and started up again as 'Hard chrome plating', where they were previously trading as 'Hard chrome plating & grinding'.
Sounds good to me - I have a tiny bit of pitting on the top of both fork legs that I'd like to get sorted - do you recommend them for exhaust down pipes and general chroming as well? Got a few other bits to sort and already contacted 'Quality Chrome' in Hull but haven't seen any reviews - do you know of anyone that's used them?
- bulldogbobby
malmojoe
I had 2 sets of H1 tubes done at Philpot's for £300 the lot.
http://www.pittedforks.co.uk/contact.php
- bulldogbobby
