front brake caliper
mickscoon
front brake caliper
#1 PostAuthor: mickscoon » Tue Jul 16, 2013 2:04 pm
hi could anyone help me with a front brake caliper for a 76 z900 does not have to be perfect as i have new seals/piston bleed screw and pipe the threads are stripped in the one i have
cheers mick
000zeds
#2 PostAuthor: 000zeds » Tue Jul 16, 2013 3:53 pm
Try John Browse M/C 01978 355556
Zeds-R-Us
mickscoon
cheers
#3 PostAuthor: mickscoon » Tue Jul 16, 2013 3:57 pm
thanks for that i am going to try and helicoil it but not sure it will work with it being under pressure has anyone else tried this your comments would be appreciated
cheers mick
000zeds
#4 PostAuthor: 000zeds » Tue Jul 16, 2013 5:39 pm
Which threads in calipers are stripped :?:
Zeds-R-Us
mickscoon
threads
#5 PostAuthor: mickscoon » Tue Jul 16, 2013 9:49 pm
hi its the brake hose thread
#6 PostAuthor: Ginger Bear » Wed Jul 17, 2013 8:28 am
I can't see why that wouldn't work. The seal is made by the copper washers, not the thread.
# 104
daveltd
caliper
#7 PostAuthor: daveltd » Thu Jul 18, 2013 10:08 pm
Ive got a pair of calipers(will need rebuilt with seals etc though)are z9/z1000 calipers the same?as not 100% what they came off
dmltd
000zeds
#8 PostAuthor: 000zeds » Fri Jul 19, 2013 6:58 am
The same caliper is used on Z650 / Z900 / Z1000 and some triples but front and rear mounted calipers are slightly different.
Zeds-R-Us
Users browsing this forum: Bing [Bot] and 15 guests
