Please let me know if you've got a set of straight ones that need a good home
Z1R valves
Z1R valves
Just took the head off my TC to check the bores etc (all great) and change the valve stem seals that Big Fluff sent over - cheers Will - but we've found that most of the valves are very slightly errr, bent!
Ginger Bear wrote:Z-Power do pattern valves at a reasonable price. I and a few others have used them without any problem.
hillbilly wrote:I have said before on here that the valves from a 4.2toyota landcruiser diesel.will fit with a bit of fettling.at about £8 each.its a lot of expence spared.seeing as zed ones are probly £40each.
Thanks guys, but looks like my mate has already sorted it! Not sure if he was going to keep it a secret, but hopefully I'll have a head full of straight valves very soon
