hi, can anyone help with some parts please for a z1r. as i am near to getting the kosman kit welded on and the frame painted, so
i need......
a throttle tube, the bit cables connect to.believe same as gpz550 d1
a hazard lights relay and an indicator relay and a strap
a sidestand
an alternator blue plug with a small amount of wires with it
seat base, or a tatty seat as will only be using the base.
front footrests, or a drawing /template of how they bolt onto the frame as i want to make brackets to match my bandit rear footrests, but in std z1r position.
know i am asking a lot but i have been watching ebay for quite a while now and no joy on these bits, will obviously pay . thanks ross
z1r parts
Ross dont understand what throttle tube ?
Indicator relay readilly availablefrom VWP
Hazard relay any modern timed relay will do that with a few mods
Side stand cant help
May have the plug will look
Think ive got a tatty base
Pretty obvious were the footrests bolt theres two threaded holes at the bottom of the frame V section in a 45 degree line below the front of the side panels engine rear these take two studs the footrests bolt to them
Pm me on hols at present
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
