SET OF CAM CAPS Z900/1000
I believe I have a set of caps from a Z1000A2 head.
I will check tomorrow lunch time and send you a text.
Adrian
Adrian
Pigford wrote:Cheers Mr Puffin - me bid is in
No Problem good to be able to help
By the way same seller has a set of cam shell bearingslisted
Ginger Bear wrote:Just like buses eh Piggy......... Non for ages then two come along at once.
Seems to be allways the case
Once I have some shells - I'll remove the valves and set it up with the cams & check they turn by hand. I will also visually check clearance by eye in a dim room with a torch
Sounds stupid, but you can see any gaps by the light
These bikes are so old now, 99% of them are running with excessive cam clearances - so as long as they ain't tight - should be OK
Obviously, if the bike runs noisy then I'd have to do the plastigauge bit
Piggy, I was watching these for meself.
http://www.ebay.co.uk/itm/380491805249? ... 1423.l2649
Let me know if you plan to bid on 'em.
