float level gauge
float level gauge
can anybody lend or sell me a float level gauge for a z1, the 17mm drain plug size one.....cheers baz
or make your own out of an old drain screw( any old thing from an autojumble , so long as it's the right thread) , drilled out and a brass hose connector soldered onto it ,(I used a vacuum takeoff connector that was surplus from my scottoiler kit) and a length of clear plastic pipe. Total cost zero and still going strong after 20 years.
gray
